Hi, yes of course, the shop can take up the quality control issue with B&O -I was watching a TV program recently about the rigorous testing Nokia handsets go through - 1,000,000 key presses, tumble tests, frozen to -20 degrees, heated to +40 degrees etc. You might have expected if you have got the nerve to sell a £175 remote control then it should be subjected to the three week Sensotronic test - and pass - at the very least. Must be a faulty batch.
