Latest post 05-25-2009 3:31 AM by timhanna. 1 replies.
Page 1 of 1 (2 items)
  • 05-24-2009 2:39 PM
    Beo5
    Hi all does anybody know how to set an option 1 or 2 on a Beo5 i wish to set my Beocenter 6 to option 2 many thanks
  • 05-25-2009 3:31 AM In reply to
    Re: Beo5
    i think if you press the centre buttom and the power off bottom at the same time you enter a little "service" menu. The letters should go red. Then you press config or something and it does it all for you automatically...
