Latest post 05-14-2009 6:24 PM by Friedmett. 3 replies.
Page 1 of 1 (4 items)
  • 05-14-2009 12:58 PM
    How to record to cassette from turntable on beocenter?
    9500 with a beogram rx2 attached. is it possible to record to cassette from the turntable?
  • 05-14-2009 1:30 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: How to record to cassette from turntable on beocenter?
    Yes,
           select "phono" and then press "record" twice on the cassette section either using the touch panel or remote.
    Chris.
  • 05-14-2009 5:26 PM In reply to
    Thanks very much.
  • 05-14-2009 6:24 PM In reply to
    Actually when you push record once you can set the levels and dolby unless you use the auto setting.
