Latest post 06-12-2009 2:01 PM by stotty1111. 2 replies.
Page 1 of 1 (3 items)
  • 06-12-2009 12:30 PM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    AV2 Expander problems
    Got one of these beasts off Andy of Weston on appro so to speak having difficulty getting it to work !
    Peter has very kindly been of assistance in verifying the power pack is the correct one.
    However the pic on the case indicates the +ve supply line is the centre of the socket and the outer sheath is negative - the power pack has been setup in this manner but the piece don't work, have opened up the box and the socket on the board appears to take the +ve feed onto the -ve  side of the first decoupling electrolytic cap this cannot be correct tried the supply the other way round still don't work !
    Suggestions gratefully taken onboard!
    Come on guys/gals help please!
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 06-12-2009 1:53 PM In reply to
    Re: AV2 Expander problems
    I used to use one and I do remember having to reverse the polarity of the power adapter to get it to work! What is your TV? What do you connect at the back of the expander. p.
  • 06-12-2009 2:01 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Got an mx7000, also a 4000,ie  the current beast - use av2 connection - but without it connected to anything would assume the on / off led would light or does it need to be in service so to speak with a signal from the tv?
    Have also replaced the on board 15v zener to no avail
    t
