Latest post 07-06-2009 5:48 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 07-06-2009 1:46 PM
    • Orange1
    • Not Ranked
    • Joined on 06-17-2009
    • The Netherlands
    • Posts 11
    Connecting Beosystem 2500 to Sony Bravia LCD TV
    Hello all,
    I have a question can you connect the Beosystem 2500 (link: http://www.beoworld.org/prod_details.asp?pid=417 ) to a Sony Bravia LCD TV. Cause we wanna use the superior loudspeakers of the Beosystem instead of the simple speakers that are build in the LCD TV when looking at and listing to concerts etc from DVD.
    Can i use it as a receiver?
    If so which cable do i need to connect them and in which connection?
    Thank you for the answer in advance ;)
  • 07-06-2009 5:48 PM In reply to
    Re: Connecting Beosystem 2500 to Sony Bravia LCD TV
    If you have a line out socket on the TV (probably RCA plugs) you need a two RCA to 5 pin DIN lead which you run to the Aux on the Beocenter 2500. Select Aux and you will be there.
