Latest post 05-05-2009 4:56 PM by Medic394. 4 replies.
Page 1 of 1 (5 items)
  • 05-05-2009 3:19 PM
    New Sky Epg
    Hi
    Is anybody else having problems using Sky via the new EPG with their beo5????  when i push stop it turns on my hdr1 inside my bv9 and i cant seem to do fastforward and then instant restart, its driving me craaaaaaaaaaaaaaaaaaazy!!!
  • 05-05-2009 4:39 PM In reply to
    Re: New Sky Epg
    Hi i have my sky hd box connected to my Beocenter 6 and this should work on the glass panal if you press pause that should correct the problem
  • 05-05-2009 4:42 PM In reply to
    Re: New Sky Epg
    by the way if you playing back a recorded programme in the middle of the Beo 5 you have the ok button to the right and left this is rewind and forward
  • 05-05-2009 4:47 PM In reply to
    Re: New Sky Epg
    yeah, thats how it used to be but since the epg change i have to do go then forward everytime i want to increase/decrease the speed.
  • 05-05-2009 4:56 PM In reply to
    Re: New Sky Epg
    the way i stop a recorded programme is press the pause button on the glass display then press again to resume
