I have the Beocenter 9500 and it has extremely low volume. Any Ideas on what it may be?
Hi Clifford
Try to change the mute relai .Is it the problem no matter what source you use(radio cd tape?)
regards
jan
Yes it is the same no matter the source. Tape CD Radio, they all work but with very low volume even on max. Same with the Headphones Low vol even on max...
Try the the speaker 2 - sockets, they have no relay. When it's still low, there will be a different problem.
