I tried to copy a wmv file 720x576 - bitrate 8548 to BeoMaster5 in the fileshare. It´s VOB files from a DVD converted to one wmv file.
It dos not appear in the PHOTO on my BV7, but I can see the wmv file in the fileshare and it plays well from the fileshare.
Is there a limit on how big files can be?
What seems to be the problem?
Another problem I have when I use PC on the BM5 is that the resolution is low. I have seen that the resolution can be higher but I dont know how to change that. Hope that you can help me.
