Hi all
Been playing around with the wall mount for an MX4002 to carry (in my case) a sky box.
Have now achieved this using a shelf from an MX7000 stand(the one that slots in under the top support plate) - I discovered the slots were set too close togther by about 5mm each side so the plate slots needed widening by 5mm - did this by drilling two small 3mm hole outside the punched slots then carefully using a hand held junior hacksaw blade cut out the intervening metal - finally finishing off with a fine small file to tidy up the enlarged holes - still cannot figure how to load pics here so use the link to view pics unfortunately they are rather poor light conditions were not good - if any interest will try to get some improved pics
http://i74.photobucket.com/albums/i252/stotty1111/IMG_1024.jpg
http://i74.photobucket.com/albums/i252/stotty1111/IMG_1025.jpg
http://i74.photobucket.com/albums/i252/stotty1111/IMG_1026.jpg
http://i74.photobucket.com/albums/i252/stotty1111/IMG_1027.jpg
http://i74.photobucket.com/albums/i252/stotty1111/IMG_1028.jpg
http://i74.photobucket.com/albums/i252/stotty1111/IMG_1029.jpg
salut
T
I always try to operate using/following the KISS principle -- Keep it simple stupid!
