Hope somebody can help me with the following idea:
My avant is dying; it will shut down due to an error quite frequently; repairing it will cost 600 euro.
Therefore I expect to buy a new b&o tv by the end of this year (I want to wait for he bv10; and then decide btwenn bv8-40, bv10 and bv7-40).
However; I want to create an intermediate solution:
Buy a "cheap" 28 or 32 inch lcd with 2 purposes:
- use now as main telly
- use later as bedroom telly
To use it now as main telly I would like to connect this lcd to the avant; in other words; take the tube out the avant and directly mound the lcd to the avant frame. This way I would still like to use the following features of the avant:
- Center speaker (must)
- DD decoder (must)
- masterlink connection (must to operate connected bs9000)
- stand movement (would be nice)
- display (would be nice)
I know some people on this forum did something similar (or muvh more impressive) and I would like to get instructions/ideas how to create this. One of the things I am, for instance, not sure about is what to do to "trick" the avant to avoid errors causing the tv to switch off automatically.
I hope to get a lot of usefull feedback!
Thanks,
Bieele
