Latest post 04-02-2009 8:35 AM by Dave. 11 replies.
Page 1 of 1 (12 items)
  • 04-01-2009 6:40 PM
    • Luke
    • Top 200 Contributor
    • Joined on 02-03-2009
    • Switzerland
    • Posts 286
    Beosound 3 earthing.... through me??
    When my beosound 3 is plugged into the charger and I touch the aluminium it kind of zaps me. Not strong or painful.... but it is earthing through me. Does anyones else do this ? or should I take it for repair?
    Thanks a lot
    LukeYes -  thumbs up
  • 04-01-2009 7:51 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: Beosound 3 earthing.... through me??
    90% of my B&O does this. Completely normal.
    Besides, why would you take it for repair? It is still working perfectly is it not?
  • 04-02-2009 1:09 AM In reply to
    • Luke
    • Switzerland
    • Posts 286
    Well... that was the point of the question. If it is normal.... because if it wasn't then it would need repair.
  • 04-02-2009 1:48 AM In reply to
    Hi Luke,
    I don't think you should be getting 'zaps' from your system caused by electrical current charging the casing. Neither of mine including power link speakers have this problem.
    That said, as you say this is 'zaps' and Dave has the same issue (and living in dry S. Aus) could this be static electricity build up, from say walking on the carpet/ floor finish, if where you live is extremely dry?
    Just a thought....
    Laurence.
  • 04-02-2009 1:55 AM In reply to
    • Luke
    • Switzerland
    • Posts 286
    It isn't little static type shocks.... it is more that the whole radio vibrates when u hold it and it is on the power...
    You can actually hear it as you run your hand down the of it... quite strange.
  • 04-02-2009 2:01 AM In reply to
    Hmmm,
    Well, could well be some sort of 'earth leakage' then, so if it worries you, and you don't like being zapped I'd take it in for service. As I said, I've never experienced it with my systems.
    Laurence.
  • 04-02-2009 3:01 AM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Nothing to worry about, and nothing to repair.
    I had the same "problem" last year and started a topic about it.
    http://forum.beoworld.org/forums/p/11393/85049.aspx#85049
  • 04-02-2009 3:08 AM In reply to
    • Luke
    • Switzerland
    • Posts 286
    Ahh excellent. That was what I needed to read !! Dave.... I read in the other post about rubbing your ear against the metal part. Can I just say... that is dedication. Mebbe I should try my tongue? hahaha
  • 04-02-2009 4:02 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    It is also not uncommon for EMC reasons to bridge the double insulation barrier with a type-Y capacitor which can result in a small (safe) leakage current.
    I'm not sure whether this will be the case in this instance however.
  • 04-02-2009 4:51 AM In reply to
    Puncher:
    And I thought I was crazy! I think I noticed this first with my Beocenter 2800 - I felt the vibration, but only when I slid a finger on the metal parts, and the power was on. I don't think the kit from this era had much thought on EMC, so there's probably no such cap in them.
    -mika
  • 04-02-2009 8:16 AM In reply to
    • Michael
    • Joined on 05-23-2007
    • Atlanta, USA
    • Posts 318
    We used to have this with certain appliances (Washing machine etc.) until we did a major renovation and built a more robust grounding arrangement at the point of electrical entry on the house. Curiously, we've got a half acre of blueberries on a hill with big, high-voltage power lines crossing our property above them. While still on the bush they exhibit the same electrical 'vibration' as if they've become natural little batteries and are grounding to your touch. It's been the source of a lot of family jokes but they taste great and the EMF levels are surprisingly low at that location.
    -Michael
  • 04-02-2009 8:35 AM In reply to
    • Dave
    • Posts 2,328
    Luke :
    Well you see, i was cleaning and accidentally rubbed past it! I experience the same senstion from the Television anntenna.
    But hey what can i say, i'm at one with my B&O Laughing. The fact of the matter is, it's very normal. EVERYbody? Rub your ears against an aluminium part of some of your B&O! :)
