Latest post 04-05-2009 12:31 PM by stotty1111. 4 replies.
Page 1 of 1 (5 items)
  • 04-02-2009 7:27 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Din plug wiring for ir eye
    quick question anyone give me the wiring layout for the din plug on the end of the ir eye cable ie the solder side connections - been looking around the site for the info but can't find it
    cheers
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 04-03-2009 6:30 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Din plug wiring for ir eye
    Have you looked HERE tony?
    Andy T.
    Poor me, never win owt!
  • 04-03-2009 8:07 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Thanks for that Andy - no I hadn't found it - however, I want info on the other end ie the din plug, I have the eye wired with a 5 core cable and a cut end where it 'd plug into the ml/mcl, passive etc
    Thought one of the techies might have helped!
    Bonne weekend - misty here in Nth Worcs!
    Tony
  • 04-04-2009 6:37 AM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Check image below!
  • 04-05-2009 12:31 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Thanks Gerd - close inspection of the plug revealed the numbering sequence or non sequence - about to go and restick it all together !
    salut
    t
