I havving a problem with my B&O 8000 receiver. It had been working fine until yesterday. At the moment, all the lights go on, but it does not work. The turntable works, but not the receiver. I did have a power surge in the room a few days ago, but not with the electric wall outlet that the system was plugged into. The power surge was resolved, not by reseting the switch on the the main apartment circuit breaker panel, but by simply pressing the surge button on two strips that I was using in the other part of the room. The lights never went out. I mention all this to let you know what has been going on, but I don't think it has anything to do with the B&O which is in the other part of the room and connected to another outlet.
Anyway, the prolem is that the light on the recevier goes on, the panel lights up, but it doe not work. Does anyone have any ideas about why this would happen suddenly? The sytem had been working until yesterday. Any advice you might have would be really appreciated. A visit to my local B&O fiix-it would correct the problem at a high price in Manhattan--and I have no way of really telling what the problem is. Donald
PS: I am using a spare B&O 8000 receiver in the meanwhile that is working fine. Donald
