My Beocenter has started having a really weird problem - sometimes i can only get sound from one of the speakers (Beolab4000's). I say no sound..there is some audio but its so quiet you need to put your ear against the speaker to hear anything, whilst the other channel is working normally.
Some days the system works perfectly, some days it doesn't.
I have tried swapping the cables over in the two datalink sockets but that makes no difference. The same problem also occurs using the headphone socket.
I have also tried swapping the datalink cables whilst the cd was playing (ie - powered on) and i did notice that if i unplugged the working speaker, then the problem speaker would spring to life. I have tried using a different datalink cable but i'm not sure whether that cable is ok...i'm going to dig out the multimeter to test the cables for shorts
The problem occurs both on cd and radio sources.
I would appreciate any suggestions regarding this baffling problem.
thanks in advance
adam
