Latest post 03-22-2009 3:50 PM by ouverture. 3 replies.
Page 1 of 1 (4 items)
  • 03-22-2009 11:23 AM
    what DVD player is Beo4 controllable?
    hi all
    can you tell me, are there any recommended DVD players that you can control via the Beo4, or do i have to go down the Lintronic route to use them?
    thanks
    kevin
  • 03-22-2009 12:52 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: what DVD player is Beo4 controllable?
    I would suggest that you go for linktronic or you can contact Beowrold member Ulf who can actually convert any DVD player you want to become compatible with Beo4. I already have 2 converted from Ulf for many years and they are still working perfectly!!!
    Best regards
    Spiros
  • 03-22-2009 3:25 PM In reply to
    I have an Avant TV with a DVD Controller  Mk II  Type 4047
    http://www.beoworld.org/prod_details.asp?pid=1272
    This Scart cable connects to the TV and DVD player, it has an additional IR eye which sits in front of the IR display of the DVD player and allows control of non B&O DVD players using the Beo4 remote.
    A thread about the DVD Mk I and Mk II controllers is on Beoworld
    http://forum.beoworld.org/forums/p/18123/134144.aspx#134144
    The non B&O DVD players it works with is rather dated now, but I have an excellent Panasonic  DVD-A360 which is a much better player than either the B&O DVD1 or DVD2 players, even the built in DVD player on the newer Avants is not up to the usual high quality B&O standards we have all come to love and cherish  :-)
    DVD Players supported by the  Mk II controller
    Onkyo DV-S535
    Panasonic DMR-E50
    Panasonic DMR-E53/DMR-E55
    Panasonic DVD-A360
    Panasonic DMR-EH54D
    Philips DVD950
    Philips DVDR70/DVDR75
    Philips DVDR80
    Philips VR200
    Philips HDRW720
    Pioneer DVDR-3100
    Pioneer DVR-530H/DVR-630H
    Sony RDR-GX3/RDR-GX7
    Sony RDR-HX1010
    Sony RDR-GX210
  • 03-22-2009 3:50 PM In reply to
    there are also the Scart leads that Linvis ( in Germany ) make
    http://linvis.de/shop/index.php/cat/c17_Scart-Controller-DVD.html/XTCsid/db28ff1de6ed0415d68dc201aee1832d
    and Ulf Kiener  ( also in Germany )  - select  Bang & Olufsen down the left hand side
    http://www.ulf-kiener.de
    and One Remote in Denmark
    http://shop.oneremote.dk/catalog/index.php?cPath=43_44
    and Keymaster from Stone Design  ( also in Denmark )
    http://stonedesign.dk/en/features_linkconverter.html
