Latest post 03-22-2009 5:39 AM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 03-22-2009 4:59 AM
    Beocord 8004 Hx-Pro Fault.
    Any suggestions?
    When I press the play or fast forward/rewind the tape head appears to engage but only for a second.
    In short, the tape mechanismn trys to fuction but wont.
    Cheers,
    Steve
  • 03-22-2009 5:07 AM In reply to
    Re: Beocord 8004 Hx-Pro Fault.
    Common fault - you need new belts. Martin can provide them.
  • 03-22-2009 5:32 AM In reply to
    Peter,
    I purchased 2 new belts from Martin.
    My very limited tech skills appear not to have worked.
    I fitted the belts yesterday - the wider of the belts to the large grey spindle and the thinner to the white cog.
    Wrong way round or just totally wrong??
    Steve
  • 03-22-2009 5:39 AM In reply to
    You need to check with Martin on that one! Not needed to do mine yet! Laughing
