Hello
I have a problem with my BS9000 and a pair of beolab 3.
When the power is switched on the speakers there is an annoying high pitched humming noise that I can't solve.
The noise is present all the time even when the music is playing (only heard at low volume and is drowned out at high volume).
I have used different type of powerlink cables but all of them give some kind of noise.
* Bosscom "white cables" MK3 gives a high pitched humming noise.
* Bang&Olufsen orginal MK3 gives a high pitched humming noise.
* Bang&Olufsen Beolab 5 Powerlink cables gives a high pitched humming noise.
* Bang&Olufsen orginal MK2 cables doesn´t sound like the others, with this cables I get a noise like a radio signal.
I heard that it could be possible to disconnect one of the pins in the P.L cable to get ride of noise is that correct?
Anyone with an idea of what it can be??
Best Regards
Hank
