Latest post 09-10-2009 3:15 PM by Peter. 5 replies.
Page 1 of 1 (6 items)
  • 09-10-2009 2:34 PM
    Beomaster 5500 and my ipod.
    i've just set up my dad's old Beomaster 5500 along with Beogram 5000, Beogram CD 50 and Beocord 5500.  I have 2 octagone shaped speakers with digital readouts.
    Everything is great.......
    I am wondering though if a can somehow play my IPOD librairy by somehow hardwiring to the aux?!?!?!
    Has anyone had any experience with regrads to this?????
  • 09-10-2009 2:43 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: Beomaster 5500 and my ipod.
    As simple as you'd imagined! Either connect a dock to the tape or Aux inputs or, simpler still, connect the iPod headphone out to the tape or Aux inputs directly. I can't recall the rear connection types on the BM5500 but I connect my iPod to my BM5000 via a 3.5mm stereo Jack to pair phono lead and it works fine! Good luckLaughing
  • 09-10-2009 3:02 PM In reply to
    Thank you.
    I guess then i should take a picture of the inputs at the back of the Beo master and head over to the apple store and make sure the dock connector matches?
  • 09-10-2009 3:05 PM In reply to
    The 5500 has RCA plugs on the back. I would get an iPod dock and use that with a mini jack to twin RCA lead. If you get thye one from Ridax, it can be remote control. Or do it another way and attach your computer. That is what I do.
  • 09-10-2009 3:11 PM In reply to
    Thnks Peter.  I Really appreciate it.  While we're at it 2 more questions:
    1.  Radio is a little fuzzy.  Do you have a an antenna on yours i seem to remember there was some plastic bunny ear thing my dad usewd?!?!
    2.  Tuning/programming stations was always difficlut on this thing. It's been 20 years.  Are there online operating manuals i can look at?
  • 09-10-2009 3:15 PM In reply to
    1. You need an aerial. A ribbon aerial is what you used to have - an outdoor one would be better but more expensive.
    2. Which remote do you have? There are manuals for the system on Beoworld but you need to be a silver or gold member.
