1st March February 2012
Latest post 03-05-2009 4:14 AM by davefarr. 7 replies.
03-04-2009 12:30 PM
Bentleyman
- Joined on 12-29-2008
- Rochdale
- Posts 367
Hi all,
Just collected pair of virtually mint Penta II's bought via ebay.
Connected them up to a Beosystem 2500 with Power Link cables etc.
Sound is superb - however, I was expecting to be able to get the digital displays....? Nothing!
I am using a 2-way remote (Beolink 5000) if that makes any difference...?
Am I missing something quite obvious..? Is there some switch I dont know of..? I got the original manual also & it just says displays work when connected using Power-link cables & compatible B&O equipment....
Or maybe my Power-link cables are not capable of data relay..? if so, what do I need to get the displays on..?
Cheers guys...
Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2, RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500, BL 5000, Beo4 (x2), BL 1000 (x2)
Bentleyman
- Rochdale
- Posts 367
Aahhh cheers Graham,
Didnt actually know there was such a thing as a MkII power-link cable. I shall see if Lifestyle AV has any, if not ebay...or if anyone reading this has any for sale..?
Thanks for the help.
Michael
Michael
BS 7000, BS 5500
Xseries
- Joined on 04-16-2007
- Hampshire
- Posts 433
I made up my own cables from a 100m reel I bought off ebay and 8 pin din connectors available at Maplin. I should still have some cable left as 100m was more than I needed (Penta IIIs)! What length are you after?
Brian
Bentleyman
- Rochdale
- Posts 367
Hello Brian,
I just been on the Lifestyle AV site & see that they are selling these 'fully wired' Mk II cables..
I guess I'm just looking for lengths of 3 or 5metres per cable..
Thanks, Michael
Michael
BS 7000, BS 5500
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
bentleyman:
Hello Brian,
Thanks, Michael
Why noy try www.soundsheavenly.co.uk . I suspect he will be cheaper than Lifestyle and this is the guy that makes them.
Bentleyman
- Rochdale
- Posts 367
Ok Graham, nice one thanks.
Looks like the prices between them are very similar - i'll get the MkII leads from one or the other.
Thanks for your help.
Michael
Michael
BS 7000, BS 5500
davefarr
- Joined on 08-21-2007
- France
- Posts 190
Did you check the Audio/Video switch? I bought a pair of MkII's which were advertised as defect (display not working) and got them cheap. Flipped the switch over and hey presto - perfect pair of Penta's with full displays. You won't be dissappointed with them.
Good luck.
Dave.
Am I ready? I was born ready!
Page 1 of 1 (8 items)
