Try This!
Press TV MENU
Select Setup using down button
Press GO 0 0 GO and you are now in the service menu
Press 4 for V.Tape
Check Chassis variant to see if "Internal VCR" is set to "Yes"
This is for a newer Avant, so I dont know if is exactly the same for yours
regards...
