Hi all
Got an Ouverture which will play some discs and not others - all pre recorded from major shop outlets - no problems with cdr's etc - cleaned the lens as described elsewhere - however, the problem persists - do I need to adjust the laser alignment and is it a simple task - haven't looked on the site yet for the service info but have it on my other pc in uk. Just trying to save a little time!
Salut
Tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
