Does anybody know if Beosystem 2 (softw. ver 16.2) i compatible with the Panasonic professional plasma panel series TH-42PH10
Many thanks !
Following Plasma Display Panels are supported in software 16.2
PDP 42 D5-I, PDP 42 D5-II, PDP 42 D6, PDP 42 D7, PDP 42 D8
Erik-nl:Is there really nobody wich have tried the newer panel Panasonic TH-42PH10 panel with a Beosystem 2 ???????
and I wounder that too!!!
anybody???
BV10
It will probably work well.
All the RS232 codes are the same in the different Pana panels.
So switching on and off will not be the problem. But you have to use the software of the panasonic to tell the panel what to do with the different resolutions as the beosystem2 sends a low resolution out.
Thanx Beobuddy
But I can still use DTV/DVI for a STB box with Beo4 and set the input slot on the panel to higher resolution?
I dont know how this works.
