Latest post 02-11-2009 2:09 PM by david707. 9 replies.
Page 1 of 1 (10 items)
  • 02-10-2009 4:52 AM
    Beo4 and BL1000
    I can bring everything to standby (link, audio and video) by pressing shift>standby on a BL1000 - How is this done on a Beo4?
  • 02-10-2009 4:55 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Re: Beo4 and BL1000
    Just hold the red dot-button pressed for some seconds. The same goes with BL 1000.
  • 02-10-2009 5:38 AM In reply to
    Re: Beo4 and BL1000
    ... or <SHIFT> <STANDBY> on Beo4
  • 02-10-2009 4:48 PM In reply to
    Re: Beo4 and BL1000
    shift>standby does not work using my beo4. Holding the red button does though - a useful tip and not something I remember reading in the BL1000 or beo4 manuals.
    Many Thanks
    David
  • 02-11-2009 3:45 AM In reply to
    Re: Beo4 and BL1000
    Nearly annoying as mute on the BEO4, took me about 5 years to work that one out, although it probably is in the manual!
  • 02-11-2009 8:15 AM In reply to
    Re: Beo4 and BL1000
    Yes, mute is very clumsy on the Beo4 even when you know where it is - unlike the BL1000.
    Beo4 loses the ability to change from audio to video (and vice versa) sources quickly for volume/muting purposes which can be done using the BL1000 AV button. If there's a Beo4 short cut tip for this I'd be very interested.
  • 02-11-2009 10:11 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beo4 and BL1000
    Get the Beo4 model with the AV button!
    Mute is even worse on Beo5, unless you have a supersonic thumb.
    Poor me, never win owt!
  • 02-11-2009 10:12 AM In reply to
    Re: Beo4 and BL1000
    <AV> is on Beo4
  • 02-11-2009 12:43 PM In reply to
    Re: Beo4 and BL1000
    Jandyt:
    It's still in a very awkward place for this purpose, compared to Beolink 1000. With a BL1000, you don't have to move the remote in your hand (or use two hands...).
    -mika
  • 02-11-2009 2:09 PM In reply to
    Re: Beo4 and BL1000
    ...But the AV button on the beo4 does not work in the same way so cannot be used for this function. A source button has to be used to change mode for volume and muting - again as Tournedos says you have to use two hands or move the remote because these are all at the top.
    list>link>source is yet another awkward one. BL1000 had link right in the middle of the source buttons - quicker and easier to use
