Latest post 02-07-2009 12:04 AM by expoman. 2 replies.
Page 1 of 1 (3 items)
  • 02-06-2009 1:22 PM
    • expoman
    • Top 500 Contributor
    • Joined on 04-17-2007
    • United States
    • Posts 222
    Glue suggestions for F1000 doors
    The aluminum panel on one of my B&O F 1000 cabinets is starting to peel off from one corner.  Does anyone have any suggestions on what glue will hold it together?  I have tried contact cement but the corner is curled now since it got caught on my shoe and the aluminum just pops back up after glueing.
  • 02-06-2009 2:09 PM In reply to
    Re: Glue suggestions for F1000 doors
    Contact cement should work.
    Should stay down if you put a clamp on it and leave it overnight
  • 02-07-2009 12:04 AM In reply to
    • expoman
    • United States
    • Posts 222
    I tried clamps but the contact cement just pealed off the back of the door from the spring in the bent aluminum which seems to be some form of hard rubber.
