Latest post 02-23-2009 9:08 AM by Steve at Sounds Heavenly. 3 replies.
Page 1 of 1 (4 items)
  • 02-23-2009 4:49 AM
    beolink passive
    Hope someone can help with what i think is proberbly a simple problem
    I have a beosound overture running passive speakers in one room through a beolink passive. I now want to run a second pair of passive speakers in another room independantly using another beolink passive and an ir sensor. I have connected the second beolink passive the ouverture using a powerlink 3 cable.all the speakers in both rooms are working fine when the ouverture is turned on at source, however i can't seem to get the second beolink passive to work indepenantly using the ir sensor. does anyone have the answer.
    Thanks Jim
  • 02-23-2009 5:26 AM In reply to
    • scott451
    • Top 500 Contributor
    • Joined on 05-22-2007
    • Paris, France
    • Posts 132
    Re: beolink passive
    hi,
    this may be a stupd question, but ...
    why not connect the second beolink passive with master link ?  if you want the speakers to be independant, i belive that they will need a master link connection.
    scott
  • 02-23-2009 5:27 AM In reply to
    Re: beolink passive
    To get a passive to work with a IR sensor you need to connect the passive to the Ouverture with a masterlink cable.
    Regards Graham
  • 02-23-2009 9:08 AM In reply to
    Re: beolink passive
    Hi Jim,
    joeyboygolf is correct, you need to use the Masterlink input to the Beolink passive.  Masterlink cables don't have to just run "point-to-point", they can be cut and joined using junction boxes to allow multiple connections in different rooms.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
