Drained lithium battery in the Beomaster. Replace the battery and put in new settings.
Note that first time powered up after mounting the new battery, you don't know what the settings are. You can risk a high initial volume setting. I like to power up on tape or aux with nothing playing there the first time and then change the settings.
