garry - if you're living in an area where B&O equipment has been installed in all the housing units, then the developer should have the pin code, or they should even be in the documents you've received.
If not, and if it's an official B&O installation, then the dealer that did the enterprise will be able to help you out. Just get the serial number of the TV and get in touch with them.
