Latest post 01-27-2009 4:56 AM by JC. 10 replies.
Page 1 of 1 (11 items)
  • 01-02-2009 10:24 AM
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Avant and Sky+ again
    Is it possible to set up the Avant to turn off  the TV only when in SAT. When I turn off in SAT it also sets the STB to standby!
       Jonnie
  • 01-02-2009 10:56 AM In reply to
    Re: Avant and Sky+ again
    Jonnie,
    It is possible, BUT only if you have one of the following products:-
    BeoVision 3 - 32 MK III
    BeoVision 5 - 42 MK III
    BeoVision Avant - 32 DVD MK III
    BeoSystem 2 MK II
    BeoSystem 1 MK II
    AND they have TV software version 15.1 or above.
    If you do have 15.1 or above then you can have soft standby setup on STB :
    This feature means that you can decide when, or if, your STB should enter Standby, and the setup of this function is very dependent on your type of STB.
    After selection of STB type, the following menu is shown
    The contents depends on whether one or two STBs are connected.
    The example shows 2 STBs.
    STB(SAT) off  STB(V.AUX) off
    At TV standby  After 30 min
    It is possible to choose between: After 0 min  OR After 30 min OR  At TV standby OR Never
    "Never" meaning that not even ALL STANDBY will shut off the STB.
    Regards Keith....
  • 01-02-2009 12:45 PM In reply to
    Why? I have a Sky+ box attached to my Avant DVD - it is the Phillips DVD type - and I can control the Sky+ box in all my link rooms with the Avant off. What are you wanting to do?
  • 01-02-2009 1:13 PM In reply to
    Peter,
    Did one of us misunderstand his "Problem Statement" you are correct in your statement, but I thought he is talking about leaving the STB on when he switches the TV off.
    Regards Keith....
  • 01-02-2009 1:31 PM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Peter :
    I'll give an example.
    At night when watching SKY+, if i decide to continue watching something in the bedroom and want to pause SKY and resume upstairs, it wouldn't be possible with older software. (SKY+ would go into standby)
    I updated my software for this reason and have it set to "OFF AFTER 30 MINS"
  • 01-02-2009 3:07 PM In reply to
    I just use the resume from last viewed position.
  • 01-03-2009 6:47 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    It would be easier if the Sky+ box just stayed on. I have it linked into the kitchen so have to switch it back on in there, not a big problem but would like to solve it.
       Jonnie
  • 01-03-2009 5:16 PM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Another issue is that the STB does not always come on with the TV so I have manually switch it on at the rear of the Avant. Bit of a pain No - thumbs down
    Jonnie
  • 01-27-2009 3:44 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Yo give this a bump!!!
    It is a pain now to be honest.  I switch on the none B&O tv in the kitchen and switch on the SKY+ via infra eye no problem until say. My wife switches on the Avant in the lounge with SAT button, this turns on the TV but switches off the Sky box at the same timeSuper Angry
    Is there a pin in the scart that can be removed that commands this problem?
      Jonnie
  • 01-27-2009 4:42 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi Jonnie. I'm sure there is a pin in the scart that can be disconnected, but then the STB will never come on when your wife presses Sat in the lounge.
    As for the problem on the post before, sometimes my Sky box doesn't come on when I press Sat. Instead of getting up and turning it on manually behind the Avant, I just press Menu, 1. This always makes the box fire up. Not perfect, but I can live with it.
    Andy T.
    Poor me, never win owt!
  • 01-27-2009 4:56 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Thanks for that Andy.
    Jonnie
