Latest post 01-26-2009 6:37 PM by nmartin771. 4 replies.
Page 1 of 1 (5 items)
  • 01-26-2009 5:07 PM
    Volume control - link - BL8000
    I have one strange question.
    My setup is like this: Bs2300-masterlink via converter to BC1 - BC1 digital back to Bl8000.
    And everything working fine but ....
    1. When I start tv, or CD or any source it turns on and by the default volume is 64 ! realy loud and unpleasant....
    How can I program it when I start any source for some other volume ?
    2. When I start tv-BC1 is automacly turns setup for speakers2 which means that BL8000 start to working.
    How can I setup to start for the speakers setup 1 or 2 or 3 ?
    3. On BL8000 switch unernith powerlink soket is set on middle position and working well but when I try to set L or R in some position speaker dot get signal ....
    one more thing ...
    When I pres radio bought radio on BS2300 and BC1 is on ... can I control which radio to turn on ?
    THANK YOU !
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 01-26-2009 6:15 PM In reply to
    Re: Volume control - link - BL8000
    1. Set the system to the volume you want it to start at and then press Go on the Beo4. That sets the start up volume.
    2. I think it will default to this setting.
    3 Make sure you have L speakers set to the L socket on the TV. But I don't really understand this as it should just involve setting the speaker to L and R.
    4. Yes. Menu, TV SETUP, Options, Beolink, and then set Linked Radio to Yes.
  • 01-26-2009 6:27 PM In reply to
    Peter :
    Thank you Peter for your ansfer.
    1. I didt it, when tv is on I setup wolume for 20 and than press go, but nothing .... again the same, volume starts up on 63! maybe I did something wrong.
    4. Yes my beolink is set to Linked Radio Yes, but again when I pres radio bouth radio is turning on...
    My BC1 is on option 2 and BS2300 option 0.
  • 01-26-2009 6:35 PM In reply to
    1. is solved ! Smile I didn't realized that I need to go to TV menu.
    This is my first link setup so I'm little bit confused ....
  • 01-26-2009 6:37 PM In reply to
    Peter :
    Can I change this default settings ?
