Latest post 02-09-2009 7:18 PM by Movie. 0 replies.
Page 1 of 1 (1 items)
  • 02-09-2009 7:18 PM
    • Movie
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 90
    Beo5 Config. Tool Install Problem
    My Beo5 Config. software stopped working, would not load, so I unistalled and tried to reinstall it again, but I am getting message
     "Error 1722. There is a problem with this Windows Installer package.A program run as part of the set up did not finish as expected.Contact your support personnel or package vendor.Action Uninstall, location: C:DOCUME~1\...\MS123.tmp, command"
    Dont know why it stopped working, maybe while removing some other programes I uninstalled something I should not have, what should I do to get Beo5 back.
    Movie
