Latest post 10-12-2010 4:30 PM by Leslie. 7 replies.
Page 1 of 1 (8 items)
  • 10-11-2010 11:21 AM
    Replacing beolab 2500 speaker covers
    Hi all,
    Quick question, anyone know how to remove the speaker covers off a beolab 2500 (cloth).
    And does anyone know where i could order replacements?
  • 10-12-2010 11:42 AM In reply to
    Re: Replacing beolab 2500 speaker covers
    Why won't any body answer this question. Are you all too busy doing market research for Lee!
    With your finger ends in the fret (speaker cover) material, pull the sides of the fret frame outwards and towards you. The fret should then just lift away.
    I am not sure that you can order replacements from B&O any longer. Check with your B&O dealer, he may be sitting on some stock.
    They are usually available on eBay but I confess to not noticing any lately.
    Regards Graham
  • 10-12-2010 12:32 PM In reply to
    Aha, thank you, i managed to take em off, ive also found a local store that still has some at stock, 15€ each, not cheap for a stupid piece of cloth but what do you expect from B&O ^^
    Thanks again :)
  • 10-12-2010 1:14 PM In reply to
    I think they were more expensive a few years back!
    Regards Graham
  • 10-12-2010 3:06 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Missed this, about 2 - 3years ago they sold for over £30 on fleabay which was equivalent then to about 40€+++ so by current standards a saving and new as well!
     go for it!!
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 10-12-2010 3:33 PM In reply to
    joeyboygolf:
    I would have, just came back from a days hard work at the refinery.Smile
    @Leendert86, If you're from Holland and depending on the color, you can have a set for free. I'm in a good mood today.
    You have to pick it up though...
    Leslie
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 10-12-2010 4:20 PM In reply to
    Im from belgium actually, unless u live really close to the border it probably wont be worth the trip :p
    but thnx alot of the offer !
  • 10-12-2010 4:30 PM In reply to
    I will be in Belgium (Antwerpen) next week doing a job at one of the refineries on the ScheldelaanWink
