kawo:Just wondering if there is a function that you can easily jump to the first new post from my point of view (as I used to this in most of the other forums I use).
It is quite anoying to find where the first new post starts.
Karsten
I agree, that's the my main issue with this forum compared to all the other forums I also visit, and I guess that other members that have experience from other forums also miss this important feature. To me, this is _much_ more important than the ability to create blogs and such (also possible in other software, btw ;-) )
To the admins: Are you sure that CS really doesn't have this feature? Maybe it's available as an add-on?
I must admit that I'm a bit confused by the choice of CS as forum software, in my experience vbulletin (for example) is a lot cheaper and it's easy to get good support from the large user base and it has all the features that beoworld uses, and most important: it works the way that most users expects a webforum to work. One of my favourite forums is the Swedish site www.99.se - more than ten times as big as beoworld, and a joy to use.
On the other hand, if you chose CS because of it being your favourite software and beacuse you already had experience of it, I'm perfectly ok with that, of course :-) It doesn't matter to me what software you use - use what you feel comfortable with, I'm grateful for all the work you put into this great website. I just want the forum to work the way I'm used to, haha :-) I know that a site this big is a lot of work, and of course I really appriciate your efforts - you're doing a great job.
