Latest post 01-19-2009 5:25 AM by beoaus. 3 replies.
Page 1 of 1 (4 items)
  • 01-17-2009 6:02 PM
    Beolink IR Eye
    Does anyone have a definitive breakdown of the different IR pucks from B&O. i.e the models, the differences & are they all wired up the same or are they wired differently.
  • 01-17-2009 11:41 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Beolink IR Eye
    Hi there.
    I think there were only two different ir eyes made. I think conection at least for MLinks werre the same.
    Regards
    Spiros
    Best regards
    Spiros
  • 01-18-2009 3:16 PM In reply to
    Re: Beolink IR Eye
    Thanks for the reply,
    But are they different?, do they wire up different & apart from the obvious with labels on the beolink version are there any other differences.
    Regards Simon
  • 01-19-2009 5:25 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Re: Beolink IR Eye
    Not all the details you require. I think there are 4 types. One without buttons, One standard, One that had different wiring for the original PC Office product plus something else and One that is for use with 3rd party plasmas that interfere with the standard IR puck. Part numbers could be found in the beolink manuals of various editions.
    Sorry for being a bit vague, hope that helps anyway, Beoaus.
