Latest post 01-16-2009 5:37 PM by Beobird. 3 replies.
Page 1 of 1 (4 items)
  • 01-16-2009 3:51 PM
    Non bang and Olufsen Speakers
    I have a beosound 9000 and would like to use it with DIM aplugged active speakers that are non B&O. I have heard there are several options but can't find any on the web. Can anyone help??
    Regards
    John
  • 01-16-2009 4:17 PM In reply to
    Re: Non bang and Olufsen Speakers
    Hi John,
    What brand and model of speakers are you planning to use?  The most common type of active speakers I deal with (other than B&O) are Meridian and these can vary in their suitability.  It is worth bearing in mind that some Meridian models are designed for balanced audio inputs, which adds a degree of complication when connecting to the unbalanced outputs of the Beosound 9000.  Other brands of active speakers (eg. Dynaudio) can also be connected, but some adaptation may be needed.
    Please give as much information as much as possible about what you are planning to connect and we'll do our best to help! Wink
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 01-16-2009 4:29 PM In reply to
    Will only be the B&O 9000 and then maybe something through Aux port. Like Beolab 9 and 5 so looking for similar size etc but round 2-3K mark.
    Regards
    John
  • 01-16-2009 5:37 PM In reply to
    • Beobird
    • Top 150 Contributor
    • Joined on 04-19-2007
    • Netherlands
    • Posts 506
    • Gold Member
    TP Tube (also Danish)
    http://www.tptube.dk/
     The new B&W wireless XT serie is also active, but I don't know if they're launched already
    We Can't Get Enough B&O Stuff...
