Latest post 01-16-2009 4:35 PM by Ignace. 3 replies.
Page 1 of 1 (4 items)
  • 01-16-2009 2:56 PM
    AUX AUDIO BeoCenter 2500
    I did a Beovision Avant connected with a BeoCenter 2500 by means of a Beolink Converter box. As a result the AUDIO AUX socket of the BeoCenter is in use (--> Datalink cable coming from the Beolink Converter box). This set-up works perfect.
    But now I want to expand it with a BeoGram Recorders Deck (with external pre-amplifier). But where to connect it to the Beocenter 2500 ? There is no more AUX socket available. Is it possible to use an AUX splitter or expander ? Or will this create conflicts?
    Are there any other possibilities ?
  • 01-16-2009 3:32 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: AUX AUDIO BeoCenter 2500
    You could go into one of the scart inputs on the Avant... Scart can actually deliver a very good sound.
     Weekly top artists:
  • 01-16-2009 3:53 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    There is THIS which was made by B&O. It may be just what you are looking for. Where are you located as I have one, and you are more than welcome to try it out.
    CraigSmile
  • 01-16-2009 4:35 PM In reply to
    • Ignace
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    you can use an AUX-Expander (6270345), you would only have to switch manually between the Avant and the Beogram.
    ( i already wrote that on the Dutch forum where you posted the same quesion earlier..  Wink
     Smile
