treefortwill:
Did you get the displays working using the speakerlink cables?
I have a Beocenter 9000 and some Beolab 5000's and I can not see to get the displays working.
Connect the Beolab 5000 with Speakerlink-cable to Speakers1 op Beocenter 9000.
Set switches on Beolab :
Set the INPUT LEVEL switch to position =.
Set the AUDIO/VIDEO/OFF switch to position AUDIO.
Set the MODE switch to position A.
Limited read-out on the Beolab; no indication of track, mute, sound and of video sources.
