1st March February 2012
Latest post 01-11-2009 9:18 AM by joeyboygolf. 19 replies.
01-09-2009 7:36 PM
holly
- Joined on 02-09-2008
- Posts 5
Hi Guys Have just purchased a beosystem 2500 wondering how to link it to the rest of our system? At present we have a Beocenter 1 master linked to a beolab 3500 via a junction box. Any help would be greatfully recived. Thanks in advance Paul
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
Re: Linking beosystem 2500
You also need a datalink cable and a fully wired (MKIII) powerlink cable between the beolink converter and the Beosystem 2500.
PhilLondon
- London
- Posts 2,545
Absolutely, MKII... I just explained MKII were the fully wired in 2 other threads yesterday, and now I make the mistake myself!!!
holly
- Posts 5
Thanku Guys Have had a look around and as yet not able to find a converter or cable if anyone has one for sale please email nash@matang.fslife.co.uk. many thanks Paul
holly
- Posts 5
Will do thanku All the best Paul
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
Hi all Whats the difference between a 1611 and a 1614 convereter? Just found a piece in the main site however I have an MX7000 and an overture to link up in one room , will the 1614 do the job? - If not what can the 1614 be used for? tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
PhilLondon
- London
- Posts 2,545
Il faut utiliser le 1611 avec le BC2500.
stotty1111
- Posts 924
Donc ce n'est pas le possibilite utilise le 1614 avec l'ouverture? L'ouverture c'est le mem qu'un 2500? salut t nb it's a little early on a sunday pou ecrit le francais! - pardon pou le pleasantrie(sorry for the joke!)
PhilLondon
- London
- Posts 2,545
Why did I think this thread was in French? I don't know! Ouverture is not the same as Beocenter 2500, the ouverture as Masterlink, the 2500 has datalink, so you need a converter only for the 2500. The 1611 has some extra features for the 2500, so that is the one you must use. I have it in my system and it works fine.
PhilLondon
- London
- Posts 2,545
You would need the converter between a MX7000 (Datalink) and an Ouverture (Masterlink). 1611 is recommended in all cases over 1614.
stotty1111
- Posts 924
So, I do need a 1611 for the 7000 - ouverture link - i gather the 1614 will not work - is that correct? or is it suck and see - I'm back en France end of next week where the kit is so can give it all a whizz then t
PhilLondon
- London
- Posts 2,545
If you already have the 1614, try it. From what I know the extra features of the most recent 1611 are for the 2500, so the 1614 might work in your case. If you do not have a converter and are going to get one, get the 1611 as it is the most recent one and works in all the configurations.
stotty1111
- Posts 924
Thanks for the help gents - i'll give it a whirl next week - in fact, have both 1611 and 1614 but the '11 was earmarked for another link system in another bit of the house to far to link in to this which is in the centre of an open plan living space with tiled floors and no walls to run links etc - will post pics when finished t
PhilLondon
- London
- Posts 2,545
No the Ouverture is Masterlink, the MX is Datalink. You need a converter.
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
PhilLondon:No the Ouverture is Masterlink, the MX is Datalink. You need a converter.
So does the Ouverture not have Datalink then?
Page 1 of 1 (20 items)
