Latest post 01-10-2009 4:14 PM by nmartin771. 12 replies.
Page 1 of 1 (13 items)
  • 01-09-2009 2:38 PM
    Advice on beolink ?
    This would be my setup Smile
    My question is when I connect all together how can I manage this system to work properly ?
    I want to listen cd's from BS2300 whithouth turning tv on.
    When I play music from tv to listen on BL8000 together with tv speakers.
    When I play music from iPod, not to turn TV on.
    And what kind of cable do I need from AUX BS2300 to converter 1611 ?
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 01-09-2009 3:16 PM In reply to
    Re: Advice on beolink ?
    My converter is connected with a powerlink to the audiosystem and masterlink to tv.
    You should be able to listen to music without turning tv on.
    However anything connected through a scart seems to switch the tv on...
  • 01-09-2009 3:19 PM In reply to
    You need to connect Powerlink and Datalink (aux) between the Beolink and the BS2300.
    You can listen to the ipod without turning the TV Tube on by pressing AV before calling the video source.
    BS2300 in option 0
    BC1 in option 2
    Have you verified your BC1 has Masterlink?
    You will lose 2 way control if you have a Beolink 5000 or Beolink 7000 remote.
    p
  • 01-09-2009 3:30 PM In reply to
    yes. my tv have master link.
    I never used two way control, so it is fine by me.
    You said powerlink cable betwen bs2300 and converter? regular one ?
  • 01-09-2009 3:44 PM In reply to
    I am not sure if you need a fully wired (MKII) or a thin one (MKIII).
    I have used a fully wired one, and would advise you to do the same.
    p.
  • 01-09-2009 3:50 PM In reply to
    fully wired one ? is this MK I ?
  • 01-09-2009 3:51 PM In reply to
    I think the MKI is not available any longer, but the MKII is fully wired, the MKIII isn't.
  • 01-09-2009 3:54 PM In reply to
    I see ! Thanks Phil
  • 01-09-2009 6:10 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Martin;
    Agree with Phil regarding MKII full wired.
    Are you using a Beo 4 or Beo 5 remote ?
    Cheers !
  • 01-09-2009 6:11 PM In reply to
    BEO 4 !
    And I will not change almighty beo4 !!!! Wink
  • 01-09-2009 7:36 PM In reply to
    • SWISS_2
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    nmartin;
    My apology for the misunderstanding. Please continue using your Beo 4, by all means. It is a fine remote, and will provide you want you need.
    The question was meant to ask if your Beo 4 is currently programmed for the A. AUX option ?
  • 01-10-2009 2:22 AM In reply to
    Hi SWISS !
    You dont need to apologise Smile My point was that I like more BEO 4 over Beo 5, design and apiriance Smile
    Yes I have A. AUX option .
  • 01-10-2009 4:14 PM In reply to
    PhilLondon:
    BS2300 in option 0
    BC1 in option 2
    p
    Let me see if I understand correctly...
    when BS2300 is off  pres AV option + 0
    wnen BC1 is off   pres AV option + 2
    and then that is all.
    Now I'm using radio on BS2300 and when I call radio BC1 not responding which is ok by me.
    I will have this feature when I setup my link like that ?
