Latest post 01-25-2009 5:50 PM by Josafan. 7 replies.
Page 1 of 1 (8 items)
  • 01-23-2009 11:35 AM
    Beocenter 8000, possible to replace CD? Value?
    Hi, second post here.
    I have got a Beocenter 8000 on the hook. I have a pair of questions:
    The CD does not work. It is a repairman how is selling it so I am thinking it is nothing you fix easy. Can you buy and exhange the whole CD mechanism or parts?
    I have always wanted a 9000 och 9500, but I liked the black finish on this one, is it much worse than the 9000/9500?
    How much is a unit with non-working CD worth?
    Thank you for answers
    Filip
  • 01-23-2009 11:53 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beocenter 8000, possible to replace CD? Value?
    Hi Filip and welcome to Beoworld. CD mechs are no longer available as far as I know. Although usually it is a problem with a bad capacitor. An 8000 with the same problem sold last week on Ebay for just over £100.
    CraigSmile
  • 01-23-2009 11:59 AM In reply to
    Thank you for your response. Ok, I see. He is asking more than the double. If it isnt the capacitor, what could it be?
    Neg. aspects of the 8000 model compared to 9000/9500?
    Thank you :-)
  • 01-23-2009 12:04 PM In reply to
    There's always the possibility that yours suffers from the canonical C2103 problem, like many of the B&O CD players from this era. This is easy to fix by someone familiar with these things (not knowing your repairman, I can't say if he has tried this already).
    However, there might other problems as well - mine apparently had a servo board with some bigger problem. I had pretty much given up, but then a BC8000 CD mechanism turned up on eBay and it worked straight away.
    (I always thought the CD mech was a one-off for this model, but I recently had a BC9500 for repairs and it had exactly the same mech - the laser on that was dead, but I managed to make that one work with the mechanics of my spare unit and the original servo board.)
    About the worth, it's hard to say - I like the looks even better than the "mirrored" BC9500, but the lack of link support and active speaker connections make it a bit more limited in some environments. Anyway, you don't usually see clean and working specimens from this series exchange hands for less than 300-400 euros. I don't think I'll sell mine, though!
    -mika
  • 01-23-2009 12:27 PM In reply to
    Well, I don´t know the repairman personally. I went by to buy some lamps to a another vintage Sansui receiver. I normally try to fix things by myself. I have never left anything with a repairman, YET. I don´t know how good he is, maybe not the best, and definetly not a specialist at B&O. I am thinking of exchanging some stuff which I don´t like for this unit. I am not having a complete B&O home so I wont be needing links. Although, the possibilty to use active speakers would have been nice.
    If I "buy it" I rely on this forum to get it working ;-)
    Thanks for comments
    Filip
  • 01-23-2009 1:16 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Is he seriously asking £200 for thisSurprise
    The BC8000 is definately the least specified of these beocenters and what he is in effect selling is a £200 (plus) radio cassette player at present. The amp isn't a particularly good one in these models so the lack of powerlink for active speakers really does make it quite limited.
    I wouldn't personally give him more than £50 for it as it stands, £200 would be a real gamble in the hope it is a simple fix IMO.
    Chris.
  • 01-23-2009 1:24 PM In reply to
    That was the type of response I wanted. I also thougt it was expensive for a non-completely-working unit. Anyway, B&O has good reputation here in Sweden. We will see how it ends, nothing is impossible. I have lots of units "which I dont care about and almost paid nothing for". We will see.
    Thanks for you response!
  • 01-25-2009 5:50 PM In reply to
    Are they easy to work on?
    Chaning the capacitor, is it a difficult operation?
    I have only worked japanese 70s gear and they are easy to open and understand.
    Thanks Filip
