A friend of mine wants to connect his BM5 with his BV7. He needs to run a cable in a hidden wall, but the connectors are too wide. His dealer recommended a convertor, sender and receiver (Gefen) who can send hdmi signals over CAT6, but he wants to avoid this solution.
Now I found a company who sells hdmi-cable on reel, and also seperate connectors that needs to be soldered. Question is, does it work and is it stable enough? Or can I cut a cable, and solder it later? The distance is about 8 meters.
