Latest post 01-05-2009 8:24 PM by Nick12345. 10 replies.
Page 1 of 1 (11 items)
  • 01-04-2009 7:32 PM
    Avant Speaker Cloth Removal
    As mine in now dirty grey instead of "clean" grey - I'd like to remove and clean it. How do I remove the cover from the chassis?
    I reckon I can clean it with soapy water and use a hairdryer to dry it - but any help would be appreciated.
  • 01-04-2009 8:25 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: Avant Speaker Cloth Removal
    I'd take care in the cleaning process, the cloth is difficult to clean, the silver covers on my 4000's didn't really clean up perfect, but i put them in the sink with luke warm mild detergent water and a soft sponge. If your using the hair dryer put it on a low heat setting because you don't want the glue to disintegrate. If it's sunny over there lay it upside down on a grid or a towel in the sun...
  • 01-05-2009 8:16 AM In reply to
    Dave:
    It's snowing here right at the moment - I guess that is not really sunny.
    Back to the topic: I would leave it as it is - I've tried to clean speaker cloths several times and they always look worse than before afterwards.
  • 01-05-2009 9:22 AM In reply to
    • tpwuk
    • Not Ranked
    • Joined on 01-05-2009
    • Posts 15
    Hi there...my first post!
     I once had the speaker frets on my Century dry cleaned....they came up like new!  Local dry cleaners charges me £5...bargain!
  • 01-05-2009 10:20 AM In reply to
    I'd like to know though how to get the cover off the Avant if anyone can help me with that.
  • 01-05-2009 10:38 AM In reply to
    You CANNOT take the cover off of the plastic holder as you can see from the picture below because it is bonded into the plastic on the four corners and along the edge seam.
    Regards Keith....
  • 01-05-2009 11:22 AM In reply to
    i just hoover mine VERY carefully , seems to do the trick
    just don't use the metal edge of the hoover end , use a plastic one or you might tear the cloth !!
    popgear is grate™
  • 01-05-2009 12:37 PM In reply to
    and how do I get the plastic cover off the tv in the first place?
  • 01-05-2009 1:17 PM In reply to
    -deleted-
    • B&o bottle opener
  • 01-05-2009 1:21 PM In reply to
    Nick12345:
    You are a gold member so can I suggest that you download the service manual where you will find comprehensive instructions!Erm
    Regards Graham
  • 01-05-2009 8:24 PM In reply to
    got it now - thanks to all
