Latest post 01-04-2009 1:22 AM by Spiros. 1 replies.
Page 1 of 1 (2 items)
  • 01-03-2009 9:23 PM
    BEOPORT PROBLEMS AGAIN!!!!!!!
    Hello All
    I wrote some time ago re problems I was having with beoport and the new version of itunes... Eventually the problem was fixed by installing the new leopard operating system and latest version of BM Link...
    The problem was fixed, or so i thought.... (apart from the regular re boot required when net radio encountered dead links).Now a new problem...beoport happily working (via itunes 8.0.1.. (12) on an IMac connected via materlink link to beocentre 2). Playing any net radio station i tune into.... find a station i like, listen for 30 minutes or so then try and change to another station or NMUSIC. Nothing happens..the link between the itunes library and remote appears broken!!!! (nothing wrong with beo4 remote). Switch to N.MUSIC on beo4, beocentre 2 display responds dutifully and says N.MUSIC but the same radio station keeps playing!!!!!!!!! Then i have to switch computer off reboot and all is fine again.
    I've uninstalled/reinstalled BM Link software and still this happens.This is driving me mad.
    Can anyone help before I throw my beoport and mac out the window??
    Yours in frustration
    David Coyne
    Sydney, Australia
    BV8-40, BC6-26, BC2, Beolab 9's, Beogram 7000, Beogram 9500, Beoport, Beotalk 1200, Beocom 6000, Beolit 1000, 800, 700, 600, 400
  • 01-04-2009 1:22 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: BEOPORT PROBLEMS AGAIN!!!!!!!
    Hi Dave,
    No need to through away anything. Some times incompatibilities happen. I've the same problem in a PC!!!! due to the TV tuner card.
    I would suggest that you reinstall everything although I assume you have already done it.
    Keep calm!!
     Regards
    Spiros
    Best regards
    Spiros
