The 4705 is very difficult to get working properly and the three head design was tricky to set up. The 4715 has the same basic mechanism - the only full B&O design - but is more likely to actually work. The 4705 is rarer so if collecting, it is the original one, but I wouldn't put a tape near it that you value!
The best cassette deck made by B&O is the 8004 - reliable and superb performance.
