Dave: Ever considered Bose? lol
Probably said by a member who doesn't have any knowledge about electronics...I'll take this as a personal offence!
For more then 20 years already a B&O fan, but then again realistic about it's performence.
Firstly, I understand the ABL function quit well.
Secondly, some electronic parts do not work as well as when they were mounted. Like capacitors for instance.
Most older stuff from B&O like the MX'en en VX'en and so on are suffering with bad components, because they start leaking.
And that's the same with the Penta's.
And finaly, components are improved in the past years. So changing components by newer ones with the same value will achieve a better performence without abusing it's original layout.
