Great to hear your opinions - they're definitely refreshing after those not-so-good evenings spent with mixed feelings of my whole idea getting on eBay and grabbing a B&O set off there. Well, things just won't go the way you expect every time and of course it's quite depressing if it happens on your first B&O set bought - not on an LP record for example. Luckily everything is not lost though and the seller is there as well - that means I might get some of my money back, but unfortunately the set is like it is now - kind of a restoration project - and I think I'm afraid of buying these kind of items online (without seeing them in advance and being really sure about the packaging if shipped) for a while
Actually I just found my digital camera once again (sorry for the a bit soft mobile phone pictures before) and took a couple more pictures also showing the Beogram 1700 (dust cover disassembled and plate + belt + some minor, broken and not, parts not in pictures).
As you see from the pictures, it's practically useless, or, is it? Well, theoretically you could disassembly it and replace the (pretty much whole) tone arm mechanism (supposing everything else is alright inside), but guess you can't get it (a replacement one) anywhere and if you could, it would probably cost a lot compared to the price these sell on eBay for example (better to buy a new one without scrathes and other cosmetical damage). If I'm not wrong even a proper cartridge would cost noticeably - the MMC 20 S shipped with this is probably somewhere inside since I was able to get this piece of memories out:
To be very honest, the Beogram wasn't packed the way it should be - suspension wasn't locked with those 3 large screws and the plate was left in place pretty surely. There were some taping inside the dust cover, but nothing else really. It's hard to say what was taped and how since it was just a single mess and a pile of stuff when I unpacked it and opened the dust cover [:'(], but I could think of one tape on the tone arm and some "holding" the plate. MMC 20 S was maybe left on the tone arm as well, or possibly somewhere else inside the dust cover.
Of course many of you are a lot more experienced on packing turntables, but even I could say this is not the way you do it, not at all. Again it's really hard to say why did the seller pack it like this since you could really expect professional packaging reading his positive feedback and thinking about his words "can pack well" (and possibly even owning this system since bought and upgrading to a better B&O one in 1990 as he stated in the description). However, the plate has probably got off it's place first and started to bang around inside the dust cover scrathing and - breaking all the sensitive objects there. The pictures represent the damage quite well, but it looked even worse when I saw it first time - I've cleaned it a bit, sorted out things and straightened the bent tonearm for example (which doesn't help a lot of course).
Around the Beogram there were just like two layers of that big air bubble protection - how you call it - and some tape keeping it together. Then just a quite sturdy cardboard box. Not too good either. All the other items were packaged pretty much the same way in their own boxes (some extra cardboards used in the Beovox box though), but luckily they survived just fine cosmetically and so far technically, too (being not so sensitive items either). As an interesting note though, the little feet of Beogram 1700 had left pretty many marks on and through the first layer of the box cardboard which might mean it had been handled a bit roughly by DHL compared to the other packages packed the same way, but without similar marks on cardboard. Still the packing style isn't right though and the big air bubble protection isn't too strong either - the Beogram had slowly flattened it.
These need some super glue probably? They feel quite weak, some of them were already snapped when I got the speakers, but I think I've also broken at least one now
What a message again, but hopefully it's still okay
Thank you again, Webu
