Latest post 12-21-2008 6:42 AM by Jandyt. 1 replies.
Page 1 of 1 (2 items)
  • 12-20-2008 9:44 AM
    Besound 9000 IR Problems
    Please can someone offer advice on the following problems I am having with my BS9000.  The IR sensitvity of the 9000 is being reduced by the Plasma TV which is in the same room. I know this is a common problem with Plasma TV's and IR links and I was considering using an extender and attaching an IR mouse to the 9000. Is this a possible solution, if so where is the IR receiver mounted in the BS9000 as I am unable to locate it.
    The other query is, I have read that there is an upgrade available for the BS9000 that imroves the IR receiver ability to reject Plasma TV interference. Is this improvement worthwhile and is it achieved by a software upgrade or a change of the IR receiver module?. I have contacted my local B&O dealer but he was less than helpful with both of these queries
    Thanks.
    D
  • 12-21-2008 6:42 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Besound 9000 IR Problems
    Welcome to Beoworld DelboyOne.
    I can't help on this subject, but have bumped this so someone who can help might see it.
    Anyone?
    Poor me, never win owt!
