Latest post 12-17-2008 5:34 AM by phirstpro. 0 replies.
Page 1 of 1 (1 items)
  • 12-17-2008 5:34 AM
    • phirstpro
    • Not Ranked
    • Joined on 12-11-2008
    • Lincoln UK
    • Posts 8
    • Silver Member
    Sky HD & Apple TV
    Hello.
    Has anyone out there connected a Sky HD and an Apple TV to a Beovision 7-40 MkII?  If so what connections did you use and what are the settings in options?
     I currently have the Samsung Sky HD STB connected to the DVI/Digital Audio for HD and scart (on AV1) for SD with a IR blaster to control the STB.  This works OK except on start up the Sky HD switches on at first but then it switches off a few seconds later!  Once it is switched on using the Sky remote it's fine.  I am planning to connect the Apple TV via Pr/Pb/y (component) and L/R audio.  Is this the best way to do it?
    Any assistance greatly appreciated.
