Nubie here, so hoping you'll be gentle
I have the Beo 6000 Speakers but need to extend the wiring as I want to reposition my CD
Can anyone point me in the right direction to get the 8 pin extension cable please
Many Thanks
Steve
Either solder longer cables on yourself or buy female-to-female Powerlink adaptors from any B&O spares specialist. The only one I know of is AVA www.avaservices.co.uk.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
easiest way is to buy some powerlink from your dealer (just the cable, no plugs) and splice it into the existing cables. ie - cut the cables in half and add the new powerlink by soldering each individual core.
If your exisiting cable is in a wall/under the floor etc you may have to install new cables from scratch.
Hope this helps.
