Latest post 12-14-2008 5:06 AM by YannChris. 0 replies.
Page 1 of 1 (1 items)
  • 12-14-2008 5:06 AM
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    New XML file intregration
    Hello,
    I created an XML file for my STB, including a taylor-made channel menu (with logos) and a few peripheral commands which are useful on a daily use.
    As the channel plan has changed, I updated the XML file in order to get my channel buttons working properly.
    Unfortunately, I did not find how to substitute the new XML to the old one without loosing all the work previously done on the other screens of the Beo5.
    The only way I know is to remove the "old" STB version on the "products" tab, then to create a new source with the new STB file.
    When done, every screen of the Beo5 need to be updated as every manually-added button is lost (even for sources which have not changed).
    So for every channel plan change, I have to create a new configuration file from scratch.
    I don't want to use the "channels" tool, as it is limited to 50 channels per source (which is not enough) and I want the channels ordered by theme (Cinema, Music, Info...).
     Any idea?
    Have a nice week-end,
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
