Hoi Pentalex,
Een mooi bezit de beosound 2,ik geniet er zelf al jaren van.
Bij deze een stukje uit een topic op het general forum:
If
you use BeoSound 2 in Mass Storage mode, or load the SD card in a PC
card reader, the card must be scanned to update the playlist file.
This scan occurs automatically if no playlist file is found on the SD card when you switch on BeoSound 2.
If
the playlist file on the SD card needs to be updated, start the scan by
pressing and holding both "Down Arrows" buttons for two seconds. During
the scan, BeoSound 2 beeps at three second intervals. When scanning is
complete, playback starts automatically.
Switching off BeoSound 2 stops the scan. However, this produces an incomplete playlist file.
Hop dat dit je helpt..
W.
Why we're on this planet? Because that's where they have B&O
